Juz110
- Apr 21, 2021
- 5
I have a 2mx2m pile cap that is 1 meter deep on 4 piles with 1.8 meter span and 1.4m span in another direction. A 300x300mm column with 2500kN is applied on top with a eccentricity of 300mm in 1.8m span. Refer below.
I have designed the pile cap with strut-and-tie method, check the strut capacity and provide 10N28 Bars at the bottom in both direction with cogs as tie. But I didnt provide any shear reinforcement. Now my question is, if strut-and-tie is used, do we need to check beam shear as well? (Because if we do, there is no chance the concrete shear capacity is adequate with given 2500kN axial load). I use Australian Standards but open to anyone's opinions.
Much appreciated.
Much appreciated.
