braves25
- Jan 2, 2004
- 64
Hello all,
See attached picture of what I am referring to here. How do y'all go about designing the portion of wall under the window? In the picture, the two windows at each side of the main entry, I would typically design the sill to transfer the wind load to each jamb. However, where the door occurs, this cannot be accomplished. I know Simpson has a kneewall connector, but I have problems making this work due to deflection (especially where I have a brick veneer). I've used a HSS member and run this down to the footing and then use the same sill design approach as noted above, but this seems a bit much. Any ideas or solutions to this common issue?
Thank you and have a great day.
