MOSTAFA86
- Mar 10, 2012
- 22
dear gents
i have a question about ESP considering esp submersible motors
which is more practical and correct way in calculating motor surface voltage,do i use the motor name plate data rated voltage and ampere or i use motor rated voltage and use motor running amp in calculating voltage drop or not.i want to know if there is a recommendation from API OR IEEE as i searched alot and found nothing helpful.
best regards.
best regards.
