testingpump
- Dec 12, 2006
- 14
Dear friends ,
In general I know that vertical pumps have better efficiency than submersible pumps, also the motor location above ground facilitate the maintenance istead of pulling out in the case of submersible pumps. But the vertical pump requires specific allignment of the borehole "well" to be installed ,also it takes much more time to install the column pipe with the shaft comparing to the submersible pumps.
I am collecting information about the differences between both type of pumps, can you please help me with any technical information for the camparing between both type of pumps, I appreciate all submitted comments that will help me in my comprehensive report regarding both type of pumps, showing the advantages and disadvantages from your experience and knowledge.
