omega_heiki
Hello! I am working on the analysis of a pressure vessel in Abaqus. The vessel has pressure loads, bolted joint loads, thermal displacement, etc. which are all axisymmetric so I have done it as a 1/4 section. The nozzles on this vessel are built in connections with tapped holes, so I don't expect significant stresses to be imparted to the vessel, and I was planning on checking the nozzle loads via a submodel. However I realized now that one of the nozzles is on the vessel axis.
Does anyone know a way to take the state of stress from around that nozzle (which is close enough to 1/4 symmetric for my needs) and apply that to a submodel? Or some other technique that would be helpful here?
