KirbyWan
Aerospace
- Apr 18, 2008
- 586
Howdy all,
I am trying to find a material substitution for EPON 828. This is to repair a DC-10 antenna panel which is a laminate honeycomb core panel made from 250°F cure prepreg fiberglass. The DC-10 SRM 51-43-01 provides a wet layup repair using EPON 828 or Hetcon 92. I want to use the same process only with EA9390 adhesive and cure cycle similar to B757 SRM 51-70-17.
The problem I am having is finding data on these old adhesives. The Epon 828 data sheet is very short on strength properties. It can be cured with dozens of different curing agents and it lists the strenght of up to 10000 psi without mentioning which curing agent was used. I can't find any information on Hetcon 92.
Does anyone have recomendations for how to substitute materials? I can't really do a test since I don't have Epon 828 data to compare against. There is plenty of data on EA9390 from Henkel and in BMS 8-301, but what do I compare it to.
Thanks to the community for pointing me in the right direction.
-Kirby
Kirby Wilkerson
Remember, first define the problem, then solve it.
-Kirby
Kirby Wilkerson
