Subtracting a Body from a Body
BreatheEasy
Industrial
Jul 23, 2013
16
I'm using Solidworks 2012 and was wondering how to subtract a solid body from a solid body.
Details:
I have opened a step file in Solidworks and have created another body (square block) using the extrude tool. Now I want to subtract the step file body from the square block so that the square block has an imprint of the step file body. The step file is of a plastic compoenent and the square block is to become a nest for the component to sit in.
Cheers
Make sure your extrude block did not 'Merge Bodies'.
Then, in your feature tree, you should find the Solid Bodies (2) folder. Expand it & select both bodies, then RMB Combine Bodies. Subtract is your Operation Type, selecting your extrude block as the main body & the STEP body as the body to combine.
