Suction pipework - distance to walls
dimble
1
I understand that generally suction pipework is generally aimed to be a distance of 0.75D from the back wall - Is this a minimum requirement?
If this the spacing of suction pipework is instead 2.5 - 3 D from the back wall - is there a danger of dead zones/vortex's forming behind the suction pipework?
Not clear on what you are asking - *back wall"?
I assume you mean a pipe sticking through into a pit from the "back wall"?
Drawing would always help.
But yes there is a risk of a dead zone, but depends a lot on size of pit, velocity and swirl in the pit and many other factors.
