CEFDESIGN
- Mar 1, 2010
- 10
We have a dwelling, which has experienced sudden settlement after 10-12 years of static performance of its foundations. In 2006 the dwelling (built in 95/96) and the surrounding ground (10-15 m in diameter) started to settle, the surface soils receded any where up to 100 mm and the foundations have continued to settle up to 200mm.
The brick veneer dwelling is on 600mm x 300mm concrete foundations with Y12 reinforcing complying with Australian Classification Medium to Highly reactive (40mm-70mm) soil types.
On conducting a range of investigations we have found the following possible affecting factors:
1909 -1986 dwelling was constructed on and/or adjacent 100 year old road (earth construction with table drain/culvert running along side, leveled most likely in the 70s-80s) – information not available at time of construction.
2006 Demolition of neighboring dwelling and concrete driveway, driveway pulverized with excavator bucket for 6-8 hours shaking the dwelling that has suffered the Settlement of its foundations.
Construction of a marina 1.5 km away, which could have led to the water table lowering (still investigating this)
Sewer works (Open Cut) some 5-7 meters from the dwelling that has Settlement of its foundations but could have extended further.
Leaking sewer for a minim 5 years a sewer line some 40 meters away leaked (12 M of sewer line was eventually replaced)
Discharging of storm water directly over the affected area for up to 18 months.
In the most investigations it was found that directly below the area of the subsidence about 5.2 meters down was a highly pliable and water reactive layer of sand/clay FINE GRAINED SEDIMENT this layer was 600-800mm deep.
Our thoughts are that the Causative factors are:
1. General shrinkage of road soils and sewer soils in excess of the surrounding soils exacerbated by the construction method of the sewer and impact from leaking/discharging water.
2. Change in the nature of and settlement of the sand/clay layer due to demolition vibration, influence of additional leaking/discharging water coupled with movement of the water table is possibly thixotropic in nature.
Does anyone have any references which would be of assistance in narrowing the cause or case study's of similar experiences that would help withe formulating conclusions.
