suggestions needed
karmesh
Automotive
Feb 14, 2015
4
how i can detect reverse motion of a wheel in a motorcycle ??
i want to detect even the slightest backward motion of the vehicle.
How slight? a microradian? a nanoradian? You need to have specifications before you can even begin to look for a solution.
TTFN
faq731-376
7ofakss
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
Does this need to be permanently installed and capable of reading at any time
Or, could it be mounted and set when the bike is parked?
And, does it need to be hidden from the roving punk hooligans?
To what end is this sensing taking place?
Assuming there is some commercial value at risk, you need not answer.
... but do be aware of the perfectly normal circumstance of the rider swerving toward and then away from the curb, stopping, and letting the crown of the road back the bike toward the curb, so as to be parked ready for departure.
Mike Halloran
Pembroke Pines, FL, USA
not more than a inch of backward motion.
permanent installation.
should be active while the bike is running,no need when it is parked.
it should be retro fit-able. I do not wish to open up any housing or anything else for that matter.
Magnets (requires mounting), through-wheel optical sensors (requires something with less than 1" between markings, such as spokes), against-wheel optical sensors (ala ball-less computer mice), MEMS gyro or MEMS accelerometer, etc.
Dan - Owner
