I'm using Abaqus 6.12-2
It is a surface-to-surface contact between 3 steel surfaces. I modeled all 3 surfaces using deformable S4R shell element. The surface in the middle acts as a double sided contact. For instance, the middle surface (assigned as Master1) and the surface on its right side (assigned as Slave1) forms Contact1. And then, the same middle surface (assigned now as Slave2) with the surface on its left side (assigned as Master2)forms Contact2.
I ran a buckling analysis and looking at dat. file & msg.file, it seems that my problem is with Contact2. I think Contact1 works fine and the surfaces interact correctly but then following that interaction, the same middle surface (used in Contact1 and 2) may have deformed a bit too much such that the slave nodes on it finds no intersection with the corresponding Master 2 surface on the left side. I know this because I have the following warning and the said node (Node 177008)is located in the middle.
***WARNING: SLAVE NODE 177008 FOUND NO INTERSECTION WITH THE MASTER SURFACE.
THE INITIAL CLEARANCE PROVIDED FOR THAT NODE IS IGNORED
Below is the code for Contact1:
*CONTACT PAIR, INTERACTION=CONTACT1, SMALL SLIDING, TYPE=SURFACE TO SURFACE
S_CONTACT1, M_CONTACT1
*SURFACE INTERACTION, NAME=CONTACT1
*SURFACE BEHAVIOR, DIRECT, PRESSURE-OVERCLOSURE=HARD
*FRICTION
0.0
*CLEARANCE, SLAVE=S_CONTACT1, MASTER=M_CONTACT1, VALUE=0.0000
And below is the code for contact2:
*CONTACT PAIR, INTERACTION=CONTACT2, SMALL SLIDING, TYPE=SURFACE TO SURFACE
S_CONTACT2, M_CONTACT2
*SURFACE INTERACTION, NAME=CONTACT2
*FRICTION
0.0
*CLEARANCE, SLAVE=S_CONTACT2, MASTER=M_CONTACT2, VALUE=0.0000
[highlight #EF2929]*CONTACT INITIALIZATION DATA, INTERFERENCE FIT, NAME=CONTACT2,
SEARCH ABOVE=10.0, SEARCH BELOW=10.0
**[/highlight]
The difference between the two codes is that I just added the *CONTACT INITIALIZATION DATA command to fix the problem of slave2 finding no intersection with master2. But it seems to make no difference. Did i miss something? How can i fix this?
Thank you so much.
