Sulfuric acid corrosion resistant coatings for Motors
oresakri
22
Hello guys,
I am going to coat Iron Motor Shell to protect it from Sulfuric acid. What do you suggest as the best coating considering corrosion resistance?
many thanks to everyone!
Straight out the door, a Novolac epoxy would be a good choice for high concentration Sulfuric Acid resistance. There are many other epoxy coatings that provide excellent resistance to lower concentrations of Sulfuric Acid and are less expensive and easier to work with.
