sulfuric acid corrosion resistant coatings
metallurgist5
Materials
Mar 4, 2011
4
0
0
hello guys,
i am going to coat Carbon steel storage tanks containing sulfuric acid 60%, at 130 degrees centigrade, with a pressure of 4 bars.what do you suggest as the best coating considering corrosion resistance, ease of application and price?
many thanks to everyone,
There are no coatings that would be suitable - even if there were would you risk a break in the coating? You might consider building a plastic tank in a fluorinated polymer (but consult potential vendors first!). I'd be concerned about using carbon steel to contain 60% sulphuric at this temperature. As TVP says - why are you doing this? A high silicon cast iron would do this job with little risk. If you were to store the acid at higher concentrations (subject to certain precautions) you could leave the steel uncoated.
to TVP: thank you for your consideration. the reason is because the corrosion rate at the moment is higher than expected. the mentioned service conditions are highly corrosive and we have no other choice except coating the inside of the tanks. the wide range of coatings had made us confused a little, i really appreciate your comments.
to enmax: thank you very much for your time and consideration. the fact is that unfortunately, the company has bought these tanks and at the moment, we want to try our best to coat the tanks rather than rebuilding them. till now, we are considering all the available coatings than can be chosen like : glass, TEFLON, Tantalum, PEEK, VITON, etc. i really appreciate your precise comments on both solutions: coating and rebuilding the tanks.
to TVP: thank you once again for your reply. i checked all the links you provided. it seems the last link does not work properly, so its a great help if you just reupload it.
at the moment, we have put TEFLON on the first rank list till now. we are also considering the following at the same time :
1- Phenolics (Concentration= 50%- T=121C)
2- Perfluoroalkoxy/ PFA (Concentration= 10%-100%- T=232C)
3- Fluorinated Ethylene Propylene/ FEP (Concentration= 10%-100%- T=204C)
4- TEFLON/ PTFE (Concentration= 10%-100%- T=232C)
5- Tefzel/ ETFE (Concentration= 10%-100%- T=149C)
6- Halar /ECTFE (Concentration= 10%-70%- T=121C)
7- Fluoroelastomers (Concentration= 10%-98%- T=149C)
many thanks to your help.
I hope you have already solved your problem. We solved some similar problems in UAE for an off-shore installation utilizing cold applied, polymeric repair compound. The name of product is Belzona.
In any case, forget a long life for your tanks.
Bye
