robot6
Chemical
- Apr 3, 2012
- 27
A lot of sulfuric acid plant vessels are brick-lined. The vessel is typically made of carbon steel. Brick lining can crack during transport and installation, and increases the cost of the carbon steel vessel.
On the other hand, 316L and other stainless steels can be found which have minimal corrosion at concentrations of around 93% and beyond. It seems, therefore, that it would be possible to construct the vessel of 316 or better alloy (Incoloy 686) and have something a bit more robust than something that is lined with brick.
Let's consider the air dryer. One can say that there will be areas of liquid which are significantly less than 93%, thus necessitating the brick lining, but is this really true? If your sulfuric acid circulation is high, then should this really be the case? My calculated outlet concentration from one such air dryer is 92.9%. (The inlet gas is guaranteed to have less than 25C dewpoint because of an upstream cooler.)
