Hi All,
I have a question on whether or not the 4 sump pumps I have installed, if operating at the same time, will work. I have (2) 4400gpm pumps leading to two separate 1.25in lines that combine to a wye flange which leads to a tee. I have a 3500gpm pump leading to a 1.5in line that leads to another end of the tee. And the 3rd end of the tee is fed by a 2500gpm pump and a 1.5in line. So this tee is fed by 3 pumps with (2) 1.5in lines and (2) 1.25in lines. After rising 2 feet, the tee leads to a 2 inch line out of the building and then to a 3 inch line. I tried modeling with the hardy cross method but keep getting lost!
Will this 2 inch line handle these flows if all pumps are on?
