mazamm
- Apr 6, 2013
- 17
- 0
- 0
Hi everyone!!
Before going through my problem, kindly check the lube oil circuit of Sundyne pump attached. We have been facing a problem with a internally shaft driven PD pump whose pressure drops with time from 3 bar. As the pressure reaches around 2 bar we have to start auxiliary pump as well. The another problem which is more concerning to me is that when we start the auxiliary pump, the pressure does not increase that time. After few minutes or may be few hours, the pressure gage shows the pressure around 5 bar. Why there is a delay in this pressure rise ?
Apart from leakage through connectors or check valve passing, what can be the other factors contributing towards pressure drop of internal pump ?
