I’m a bit out of my comfort zone/ knowledge base and need assistance (maybe to just be educated enough to define the problem completely…)
What is a good way to mix throttled liquid/ flash gas and hot gas in a low side of refrigeration system to achieve a uniform superheated vapor in a minimum amount of space? The initial design has the feed streams injected into the top of separate sides of a plate heat exchanger. At the bottom of the heat exchanger, the two streams are connected and then allowed to run through about 20' of tubing with 4 180 degree return bends. There is a liquid stream rolling along the bottom of the pipe showing incomplete evaporation is evident.
After initially seeing the evaporation was not complete and that there was a significant temperature differential across the heat exchanger, inlet piping to the heat exchanger was connected together. This visually looks a little better but there still is a liquid stream flowing along the bottom of the pipe.
The proportions of flow are 64% superheated gas and 36% flashed refrigerant liquid which is at about 0.13 quality at the beginning of the mixing. Flow velocity is about 2400 ft/min in the 20' section of the tubing.
There is insufficient room to add much additional piping. Would static mixers which I believe are typically used for liquid blending be of any benefit? Are there some other “chemical engineering tricks of the trade” that are typically used for this type of application?
TIA,
Mike
TIA,
Mike
