seconb
- Jul 12, 2022
- 11
Hi All,
The building in the attached image is to have all internal walls removed within the East portion. It is single-storey cavity walls with timber trusses spanning N to S.
I require an open space with as few intrusions as possible, without leaving any buttressing walls. Does anyone know a way to keep the exterior wall safe against wind loads that does not intrude on room space? Adding new steelwork in is not a problem if required.
