Suppress by expression and unsuppress in UG Nx
Gurusamuel
13
Hello all,
In Ug Nx. I Couldn't able to unsuppress the feature which is already suppressed by expression.
for example.
Step-1
I was applied a radius in one edge of a block.
Step-2
That radius was suppressed by expression.
Step-3
I want to bring back the original feature. I used to make unsuppress the radius. But not suppressed.
Any one can help to me the Why the feature is not getting "Unsuppress" which is already suppressed by expression.
Thanks & Regards
GurusamuelT
You'll get a better response by posting this question in the UG/NX forum:
forum561
The short answer to your question is: you will need to change the value of the expression that controls the suppression or edit the feature so that the suppression is no longer controlled by an expression.
Dear Cowski,
Thanks for your reply's
Your correct. If we change the expression value that will control suppress and unsuppress. But I Need to remove all the relations from the history, there shouldn't be any expressions without getting any effect to the feature.
Thanks for your support and I posted the same query on Forum561:Siemens:UG/NX
