Suppress "OK to delete?" dialog
Skullmonkey
Computer
How can I suppress the dialog box that warns the user that a worksheet will be permanently deleted? I'm just deleting a temporary worksheet that I used during my code like this:
Code:
Dim Wks as Worksheet
Set Wks = Worksheets.Add( _
   After:=Worksheets(Worksheets.Count), _
   Type:=xlWorksheet)
'[do work with Wks here]
Wks.delete
SkullMonkey,
Use the following:
Code:
   Type:=xlWorksheet)
Code:
Application.DisplayAlerts = False
Code:
Wks.delete
Code:
Application.DisplayAlerts = True
HTH
Mike
Thanks Mike. I knew there was a simple solution for this one.
