I am creating an assembly where some of the components are being controlled using "supression by expression".
After the expression gets toggled to "1" I need to go into the ANT and toggle the checkmark next to that component to make it visible (actually, not hidden anymore).
I believe this assembly used to work fine where the components were visible immediately, without going into the ANT, but I think I did something to make it not work anymore.
Do you have any suggestions to make the components visble (not hidden) after the associated expression gets toggled to 1?
