How do you model the surfaces for bolts. do I create surfaces for the bolt shank and the inside of the plates where the shank makes contact? Do I model the surfaces between the nut and the surface it touches as well as the bolt head and the surface it touches? If so how do I do it? I have tried many things and I keep getting a warning in the message file that says:
"contact surfaces "assemeby_bolt head" and "assembly plate1" node
number 1157 instance part-3-1 is overclosed by 116.58 which is too
severe--cutback will result. You may want to change the value of
hcrit (5.19823E-02_ on the *contact pair option."
what does this mean and what is a reasonable value for hcrit? Thanks for the help.
