Surface Design Issues
first: try change tolerance value.
Second: try use face blend.
Third: You must add face bellow existing faces.
Best regards
MANok
NX2027
TC14
Hello Jashe,
I mean: extrude free edges and sew new faces with existing sheet body, and after try add blend:
Best regards
MANok
NX2027
TC14
I agree with Manox, it's those bottom edges that are causing the failure.
extend them so the bland has somewhere to attach to. Or do a Face Blend and turn off all the trimming and sewing options, then trim it out manually.
