Jan 17, 2024 #1 TylerD Automotive Jan 17, 2024 2 0 0 US Currently we are machining parts prior to heat treat, sending them to heat to treat and then to the customer. Am I mistaken but won't my surface finish change after heat treat? Specifically referencing 12L14 Steel. Appreciate any feedback.
Jan 22, 2024 #2 drawoh Mechanical Oct 1, 2002 8,860 0 0 CA TylerD, Do you inspect your parts after heat treating? -- JHG Upvote 0 Downvote
Jan 22, 2024 #3 Wuzhee Automotive Jul 12, 2022 269 0 0 DE You can specifically state on the drawing that your desired surface finish applies before/after heat treatment. Upvote 0 Downvote
Jan 22, 2024 #4 ctopher Mechanical Jan 9, 2003 17,421 0 36 US It will change, not sure how much. But, I agree with Wuzhee, add a note on the dwg. Chris, CSWP SolidWorks ctophers home Upvote 0 Downvote
Jan 30, 2024 Thread starter #5 TylerD Automotive Jan 17, 2024 2 0 0 US OK thank you! We normally send it to heat treat and then to the customer. Upvote 0 Downvote
