surface resistivity
dho
255
i am hit by a requirement, the surface resistivity.
to prevent any electrical energy stored on the surface, the surface resistivity must be between 1 megohm per square and 100 megohm per square.
my unit are made from anodized aluminum. i searched the internet for a number and could not find one.
is there a published document on such information?
thanks.
First off, what grade & type of anodize
For instance 'Hard Anodize' is thicker and more resistive than some other types.
Not saying you can trust it in isolation but a quick Google search got me:
Unless they are measuring based on thickness of anodize layer?
i will think the thickness of the anodize layer may impact the surface resistivity, but by definition, the unit should be ohm per square.
so, that article either not valid or needs correction.
not too much info online. [sad]
It's very well explained here:
TTFN
faq731-376
7ofakss
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
There is a homework forum hosted by engineering.com:
