Surfaces
Poorpaulus
Automotive
GB
When doing a 'Delete and 'fill' command, why do other surfaces disappear? If I hover the mouse over the area where the surfaces have disappeared, the outline shows up, but as soon as I move the mouse off the surface, it goes again. I have tried rebooting. If I delete the 'Delete and fill' command and repeat it, there is a 50-50 chance of it curing itself.
Is there some setting which I am upsetting?
Any help will be wonderfull!!!!
Paul.
Are you shure that the surfaces are missing? If an outline appears when you move the mouse, I think that the surface is there because SW is selecting it. So it could be a graphic card problem. Can you perform some tests in your graphic card or try to read the file in a different system?
Good Luck
Did you run a tools\check on the model to see if there are any errors in the model?
Scott Baugh, CSWP [borg2]
faq731-376
