Hi Everyone,
I have created a surface between four curves using Through Curve Mesh. As you can see on the images the cross curves are different and the transition creates an indentation starting from the cross curve on the left. I would like to vary the direction of this indentation to match the direction of the red line.
How can I achieve this?
Many thanks for your help.
