Good day!
I am currently doing a design for temperature reinforcement for a suspended slab topping. The scheme is to use welded wire mesh 6mm in diameter for temperature bars to control cracking. To compute for the bar requirement, I used
As = 0.002bt for Grade 33. However, my concrete topping on one floor varies from 8" maximum to 2" minimum since the existing slab has a certain slope and the new usage requires it to be level.
question:
a) What thickness should i use to compute for As?
b) Would an 8" thick topping require double layer
reinforcement?
c) Other methods or schemes to obtain an effective
concrete topping?
Thanks.
question:
reinforcement?
concrete topping?
Thanks.
