I would like to know if there is such a tensioner that tensions a belt system by pulling upper belt and bottom belt closer so the tensioner itself will be suspended in between the two pulleys. If it exists, what is it called? The type of belt I'm using is 8-groove serpentine belt. I would appreciate it if anyone can give me a guide on this.
Thank you
Thank you
