SW Pack-and-Go "Include Drawings" fail--SOLVED
TheTick
10,194
For the longest time, I was having trouble getting Pack-and-Go to find drawings. When I hit the "Include Drawings" checkbox, the process would start, then hang.
Today I discovered that the culprit is "Flat View". Include Drawings works fine in Nested View, but hangs in Flat View.
A quick test here confirmed your findings. [thumbsup]
Which OS are you using?
I have no issues, but never used Flat View. I'm not really sure what the Flat View option is for.
Chris
SolidWorks 10 SP4.0
ctopher's home
SolidWorks Legion
Nested vs Flat is like the BOM's Indented vs Parts Only.
The Flat View is used when you want to sit and stare at the screen for the rest of the day. [smile]
Yes, I have seen the same issue. Leave it in nested view, select the drawings, then change to flat view. In flat view it is easier to eliminate un-needed files.
Hardie "Crashj" Johnson
SW 2011 SP 2.0
HP Pavillion Elite HPE
W7 Pro, Nvidia Quaddro FX580
