  • Congratulations waross on being selected by the Tek-Tips community for having the most helpful posts in the forums last week. Way to Go!
Sweep Along a Guide String and Maintain Cross Section Orientation
Jim0914
21
0
0
I have attached 2 pictures. One shows my cross section and guide strings. The guide strings were created by intersecting 2 surfaces. When I do a 'Sweep Along Guide' the cross section rotates slightly by the end of the sweep. Is there something I can to to maintain that orientation of the cross section?
Thanks -
Jim Weisner
Senior Designer
General Electric Company
NX V12.0.1 MP02
 https://files.engineering.com/getfile.aspx?folder=52ab65d7-7a62-48d6-add1-601bf13d9a1d&file=IMAGE_1.png
If you are using the "swept" command, I'd suggest looking at the various orientation methods available. Assuming the long edge of the rectangular section is parallel to the X axis and the short edge is parallel to the Y axis, I'd suggest starting with "vector direction" and choosing the Y axis direction. But other options may work better for you. Also, I'd suggest turning on the "preserve shape" option; it won't help orient the section, but it will keep the corners sharp.
www.nxjournaling.com
Cowski is right (as usual).
From personal experience, if you aren’t sweeping a round tube you need more than one guide curve.
"It is impossible to make anything foolproof because fools are so ingenious."
