SWITCH MODE POWER SUPPLY
jitendragorashia
6
I have heard a lot about electronic equipment operating under very wide voltage range e.g. 90 volts A.C 60 hertz to 270 VOLTS. When inquired I have been informed that it works by switched mode power supply unit. Can any body provide further informationon on switched mode supply.
[sig][/sig]
What kind of information you are inquiring? Do you need some books to read, if you do let me know and I will provide you with names.
I am a SMPS designer myself. Just let me know what are you looking for and I will provide
Paul Peters
emnap@hotmail.com
Provide Engineering services including all aspects of design, simulation, PCB Layout, Mechanical Drafting and documentations.
in SPS, some ways can be used to make the full range input.
1. add a PFC stage before Dc-Dc stage.
2. add a auto_range circuit.
3. using Flyback topology.
Also, we have some advanced topology to make it. Like, single-stage isolated rectifier with power factor correction...
