Thanks for the new version, but unfortunately I get the following errors:
Syntax errors:
Line 466: 'GetUserAttributes' is not a member of 'NXOpen.Assemblies.Component'.
Line 485: 'GetUserAttributes' is not a member of 'NXOpen.Assemblies.Component'.
Line 781: 'GetUserAttributes' is not a member of 'NXOpen.Assemblies.Component'.
Line 791: 'StringValue' is not a member of 'NXOpen.NXObject.AttributeInformation'.
Line 798: 'StringValue' is not a member of 'NXOpen.NXObject.AttributeInformation'.
Line 1162: Method 'Public Sub newContextMenuStrip_Opening(sender As Object, e As System.EventArgs)' does not have the same signature as delegate 'Delegate Sub CancelEventHandler(sender As Object, e As System.ComponentModel.CancelEventArgs)'.
Line 1320: 'GetUserAttributes' is not a member of 'NXOpen.Assemblies.Component'.
Line 1328: 'StringValue' is not a member of 'NXOpen.NXObject.AttributeInformation'.
Line 1337: 'StringValue' is not a member of 'NXOpen.NXObject.AttributeInformation'.
Line 1346: 'StringValue' is not a member of 'NXOpen.NXObject.AttributeInformation'.
Does NXOpen have an other syntax in NX85? I'm working with NX7.5, windows 7 64bit
Syntax errors:
