Dear all,
I would like to ask for an advice regarding starting of 4kW motor. We use this motor to power centrifugal pump and we need to start with start - delta starting.
My question is whether it is a good practice to switch between the star and delta contactors with PLC. My understanding was that to make sure that the 2 contactors will never be engaged at the same time there has to be mechanical connection between the contactors that prevents just that and makes sure that only 1 of them is engaged at the same time.
Recently however I found out that competing product just simply uses PLC signal (with delay I imagine) to switch between contactors. For us of course that would be much easier and cheaper. But my question is: Is this a safe practice? Are there any safety precautions we need to take to make sure we never have 2 contactors engaged at the same time?
Thank you
Jakub
Thank you
Jakub
