EmmanuelTop
Chemical
Due to the nature of NH3 and H2S components, pH value of the effluent water from Sour Water Stripper is often higher than 10 (compared to pH=8 of sour water feed). Although SWS is working efficiently, high pH value (from residual NH3) causes unacceptable conditions in the wastewater treatment plant.
So, the question is: how to reduce the pH of effluent stream and have a complete stripping of H2S (which is the case now), at the same time?
I have an idea of SWS effluent acidification, but I do not know if this is applied somewhere in industrial practice. In such case, pH controller should take the information from SWS feed control valve (flow) and effluent pH (pH analyzer) and automatically adjust the amount of acidic neutralizer that is going to be injected downstream of the feed/effluent heat exchangers. Target pH should be maintained between 7 and 8.
- What type of acid ahould be used for such purpose?
- Does anyone of forum members have similar experiences, and how did you battle against these kind of problems?
_ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _
"Our Music is New Black Polished Chrome That Came Into Summer Like Liquid Light"
