Symbol for fillet weld with no filler? 3
BigBunny
4
I have a question on how to properly call out a weld that our manufacturing team has been doing for decades. The symbol does not seem to be correct to me, so I am looking to update the drawings if it makes sense.
This is a flange welded to the end of a tube using TIG with no filler - a fusion weld. There is a small step between the ID of the tube, and the ID of the flange bore. It is currently called out as a fillet weld with 50% penetration, as they have trouble controlling distortion if they penetrate all the way through the tube wall.
A fillet weld does not seem correct since there is no filler to add material and actually form a fillet, but I am having trouble finding guidance on this one. Is this a variation on a tee weld or another type?
Pictures attached.
Thanks in advance for any help!
E
@ EdStainless
We do not know details of (OP): CODE, dimensions, materials, pressure/temperature, etc.
This sketch is like a socket weld. The 1.5mm gap is to allow free expansion of the tube during welding and to prevent cracking.
When these are done on tubesheets the rubes are expanded 'to contact' in order to prevent tight side - loose side issues.
Yes his is more like a socket weld so some gap is prudent.
