Symmetry loads and RBE3
aleximos
29
I'm trying to distribute a load through an RBE3 element that happens to be on a symmetry plane. Unfortunately I get singularity errors from NX Nastran, bcs the RBE3 element has 3 constraints from the symmetry condition. I eliminate these 3DOF from the dependency dialog, but still get singularity error. Any suggestion would be greatly appreciated!
BR Alexandros
Hello Aleximos,
what kind of solver do you use, SOL 101, SOL 106 etc.?
If you don't use ADINA solvers (SOL 601/701), similar problems with RBE3 can be solved by using of UM sets.
Please check this, it can be a solution for you.
Regards, Jan
With best regards,
Dr. Jan Vojna
Lead Engineer Development
Siemens, s.r.o.
Hello Jan,
thanks for the answer. I'm using NX Nastran solvers and couldn't manage it . I'll just not put the load on the symmetry plane :(
Aleximos,
NX Nastran uses several solvers. Different solver = different cure:)
That's why I wanted to know if you use SOL101 or SOL601.
Can you share .dat file?
I get it, it is actually very simple - just activate parameter AUTOMPC.
Have fun, Jan:)
Thanks Jan again! But still didn't manage it. Could you upload the .dat file?
Oooops sorry I already deleted all:(
But don't worry, it is simply. You have used parameters:
PARAM,PRGPST,YES
PARAM,POST,-1
PARAM,OGEOM,NO
PARAM,AUTOSPC,YES
PARAM,K6ROT,100.
PARAM,GRDPNT,0
So just add PARAM,AUTOMPC,YES (you can whenever in BULK DATA) and run the job again, that's all...
Just try this, it should work.
