Synchroflex T5 timing pulley tooth profile
xydrex
Automotive
Mar 15, 2005
38
Hi, I need to cut a timing pulley - metric synchroflex T5 (5mm pitch). Reason is - this size only goes up to 60 teeth off the shelf but we need one that is 72 teeth. So I am after the exact profile of the tooth so we can design the cutting tool for it. I have profile of the belt tooth, but pulley tooth profiles differ slightly in terms of radii on corners etc so we wish to be exact. We purchased & downloaded ISO 5294-1989 which gives this info but only for Imperial profiles (closest one is XL). Apparently the metric info is contained in DIN 7221-2, only problem is its only available in hard copy from Germany so it will take a while to arrive & we need it urgently. Does anyone have the profile of T5 pulley teeth or know where to get it for download?
Thanks.
