Synchronizers and gear oils
geesamand
688
I have a few questions about modern synchromesh designs that have been nagging me.
1) How much of a difference does a GL-4 vs. a GL-5 oil affect synchronization and synchro wear?
2) I see some mfrs using more double- and triple-cone synchros and others recommending friction modifiers to add to the gear oil. Is this to make the GL-5 oils synchronize like a GL-4?
Any other comments on this subject are appreciated.
Dave
Rather than speculate why not try it. You can always go back. Your main concern would very likely shift to operation.
They all 'work' IME. My concern revolves around chemical and mechanical wear in the long term.
So for example, will using an extra-slick GL-5 wear out the synchros in a tranny designed for GL-4? Even if the GL-5 claims to be synchro-friendly?
Dave
Some late model Corvette transmissions (ZF?) have a reputation for generating significant quantities of bronze particulate mud and require both special synthetic lubricant and frequent changes to achieve old age. At one point a few years ago I think there was just one lube in the world(maybe by Castrol) that was ZF approved.
Interesting tidbit about the vette boxes.
The autos in question are imports. Most of these trannys appear to have been designed around GL-4 properties, but in the last 5-10 years the commonly available lubes are now GL-5 rated. The manufacturers have revised their literature to accept both GL-4 and GL-5 (rumored to be because of pressure from dealerships, who didn't want the hassle and cost of sourcing GL-4 anymore).
So the question remains, is this a semantic difference, or is there a significant difference esp. w.r.t. synchronizer wear and performance?
Do these transmissions have two hypoid differentials in them?
Nick
I love materials science!
No, these are common FWD layouts with a helical final drive gear. So the contact pressures probably won't benefit like a hypoid set would.
