System sizing calculations
Railexruss
1
Greetings everyone. The image attached is a system we have been using for a garment conveyor. This system is designed rotate the conveyor chain with an mass of approximately 1500lbs. Now, the question is if I wanted to design a larger conveyor, it would require a larger conveyor chain thus, bigger chain mass, bigger diameter shaft and heavier duty roller chain, motor hp and transmission hp. I would like to find out the starting torque to move a 2000lb or 2500lb chain and determine what shaft size and motor with transmission is suitable for the conditions. help!
 https://files.engineering.com/getfile.aspx?folder=f0cc27ce-a9e3-45d7-be2f-908261e46888&file=Capture.JPG
