T-beams
RK Sriwastav
56
On what conditions, Beams are designed as T-beams?
What is the difference on the response of beam designed either as rectangular or T-beam when subjected to seismic excitation?
Ravi K
Beams are designed as T-beams when they are cast monolithic with a slab.
The design method used by the designer has no effect on the response of the beam when subjected to seismic excitation.
BA
By treating it as a T beam, you can save some reinforcing... especially for some heavy loaded items or long spans.
Dik
You're on the right track with this I believe. If T-Beam action is available, it will increase the probable moment capacity of your beam whether you choose to consider it or not. That matters a bit.
