rfgoil
- Feb 23, 2016
- 5
My table saw runs fine on regular breakers but trips the breaker on both 15 and 20 amp AFCI breakers. why is this? Someone suggested the thermal overload may be arcing and causing the breaker trip.
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Calgary said:Arc-fault protection
All branch circuits in a dwelling supplying 125V outlets rated 20A or less are to be protected
by a combination-type arc-fault circuit interrupter (AFCI).
Only the following 15A or 20A outlets are excluded:
■ Kitchen counter, island and peninsula outlets
■ Kitchen refrigerator outlet
■ A cord connected sump pump on a separate breaker (the sump pump must only be plugged into
a single receptacle and labeled sump pump use only)
Yes. Happy to help.Dik said:I assume that's in response to my question... thanks, Bill.
