Relief valves installed on ASME VIII Div 1 vessels solely for thermal expansion relief may have significant inlet flow restriction so long as the required relief capacity is met and proper operation is not affected per Clause UG-135 (b)(1).
The tube side of a water heater operates at 900 psig with steam on the shell at 150 psig and 365 degF. The tubes are designed for 1000 psig corresponding to the heater pump shutoff head and the set pressure for the ¾”x1”nps thermal expansion relief valve.
Murphy designed an acoustic interaction between the channel volume, RV inlet line and relief valve dynamics that causes chattering, valve seat damage and chronic leakage after a brief pressure transient comes along.
I would like to introduce an orifice plate at the relief valve inlet flanged connection to mess with the acoustics and introduce vapour dampening. I would also like to install a take-off and normally closed valve between the relief valve inlet and orifice to permit manual re-seating once cycling is detected.
We have tried relief valves with reduced blow down and different seat materials with no luck.
Could this work Does anyone have experience with this configuration?
