Vivek19
- Jun 16, 2011
- 8
I am in need to design the Foundation for a API Tank. The Uplift force calculated for that tank is too heavy.The details as follows.
1. Empty Load = 11,000 kg
2. Test Load = 95,750 kg
3. uplift = 119,000 kg
4. Tank Dia = 4.5 m
5. Tank Height = 5.2m
And I was informed that , the uplift load is the net value. After the deduction of the Gravity Load ,the uplift load is 119,000 kg ( 119 Tonnes).
Which looks like ubnormal.
When I referred the API 650 code , Table 5-21a - Uplift Loads.
As per the Code , for the Design pressure, Netuplift force in N = [(P-0.08th)xD2x785]-W1,
Where ,
P = Design Pressure in kPa
th = roof plate thickness in mm
D = Tank Diameter in m
W1 = dead load of shell minus any correosion allowance and any dead load other than roof plate acting on the shell minus any corrosion allowance in kN
And as per the Clause 5.12.13 : The foundation shall provide adequate counterbalancing weight to resist the design uplift loads .
Then for the given Uplift Load , the Foundation size approximately required is , 5m dia , and foundation depth should be more than 3m.
Almost the foundation depth is more than 50% of the Tank Height.It looks like un realistic.
Is there any wrong interpretation in the Uplift force calculation for the foundation.
Since , I am a structural Engineer , I am not familiar with API codes.
Please help me to resolve the issue.
With Regards,
Vivek.
4. Tank Dia = 4.5 m
Where ,
With Regards,
Vivek.
