mEng123
Chemical
- Feb 13, 2013
- 1
Hey guys,
I have been given a task involves 3 tanks, 1 vertical and 2 horizontal, connected to each other. the vertical tank is supplying the other two similar size horizontal tank. I need to find out what would the level be in the vertical tank if the other two tanks are 90% filled. I know it is a fairly easy problem but i started getting confused when I am using Bernoulli equation. I already know what the 90% level in both tank would be and I already calculated the areas and volumes. I request advice or help on this issue!
