Jul 7, 2021 #1 ilkin014 Materials Jan 7, 2017 2 0 0 AO HI All, Could you please advise me, which types of metallurgical affects has a taper boring on fittings/flanges (for Carbon and Stainless Steels)? (For example if we are going to reduce wall thickness up to 10mm?) Regards, Ilkin HASANOV.
Jul 7, 2021 #2 LittleInch Petroleum Mar 27, 2013 21,094 2 38 GB I don't understand the question. Taper boring is a machining issue where if you lubricate the cutting element, there is no impact. 10mm sounds like a lot though. Most flanges have min and max bores which may not accomdate that much. Remember - More details = better answers Also: If you get a response it's polite to respond to it. Upvote 0 Downvote
Jul 9, 2021 #3 GD2 Mechanical Sep 25, 2017 608 0 16 CA Ilkin014, Look up the flange/fitting standards and see what is the minimum required thickness. Simply put, going below the required thickness is not acceptable unless you want to spend expensive engineering analysis. GDD Canada Upvote 0 Downvote
