Morning all,
Long time lurker of these forums, first time poster today however.
Currently got a little bit of an issue, I am currently reworking an existing design in which a parallel pin drops into a parallel hole within a sliding component, used to lock it in place.
I wish to remove play from the system as far as reasonably practical, and having experimented with highly toleranced parallel parts - they are simply far too sensitive to contamination, tolerance stack-up etc in this particular application, and thus I'm looking at making the portion of the pin which locks the sliding component into place, tapered - and thus the hole into which it will seat, tapered also.
I've got some concerns about this, in that these pins are subject to a large radial force - and it seems likely to me that a tapered pin, in a tapered hole subject to large radial force will try to 'self eject', i.e. back out of the hole. I don't really have time to physically test, before I need to physically retest the entire assembly.
What is ones input on this, the only reasonable logic I can seem to apply is that if the total taper is less than the critical locking taper angle, perhaps these won't eject. Large angles obviously would eject... I only have room infact for a very shallow angle anyway. They are spring loaded, but only lightly (~20N).
Just looking for a little bit of opinion on this?
Many thanks in advance!
