Tapped hole in round part
coolcad
32
0
0
Trying to put a tapped hole in a round part. However, there is no surface for the cosmetic thread to be created. In the past I have created a c-bore at the diameter and depth necessary for the cosmetic thread to work. But this isn't a true representation of what I want. It also makes it difficult to dimension on the drawing because the hole is not a true circle.
Is this a SW limitation or is there another way?
You can add the cosmetic thread manually by going to Inseert, Annotations, Cosmetic Thread. I have seen this work when the auto-created one in the hole wizard does not.
What version of SW are you using. It works fine for me in SW2004.
[cheers]
Making the best use of this Forum. faq559-716
How to get answers to your SW questions. faq559-1091
Helpful SW websites every user should be aware of. faq559-520
Check that you have the View > All Annotations selected.
Also in the Feature Manager RMB Annotations & make sure you have Display Annotations selected
[cheers]
I am using SW2005 SP2. But this has been a problem forever. All the annotation settings are on. When you create the hole using the hole wizard, you will get an error saying that the cosmetic thread cannot be created. I created a plane tangent to the surface of the cylinder and place the hole wizard on that surface. How would you do it to get it to work?
I just click on the surface, then activate the Hole Wizard, set the options, constrain the point, then Finish ... no problem. I'm using SW2004.
[cheers]
So what were you doing?
[cheers]
I created a surface tangent to the cylinder and then used that surface to place the hole. I've always been under the impression that you had to have a plane or flat surface to create a sketch. Apparently not.
Corb: Nice trick, but I can only dimension from 1 edge of the arc. Assume in this example, the arc is drawn on the top plane: After using the hole wizard, I can dimension from the left edge to the point of the hole, but I cannot dimension from the top of the arc down to the hole point. How do you dimension or constrain it so it will not be a "floating" hole?
Flores
Arc?
[cheers]
I used Corb's method but first I created a plane tangent to the curve at the location I needed the hole. Then I make the hole wizard point coincident to the plane. Then I was able to measure from one end to further constrain it. There probably are other ways, too.
