KDB_17
- Jan 18, 2018
- 3
I am currently designing a system that requires an actuator to be fastened to a horizontal baseplate via a clevis plate. During operation, the actuator will transmit cyclic loading to the baseplate (normal to baseplate) with a high force. After a significant number of cycles, the actuator and clevis plate will be replaced but the intention is to keep using the baseplate.
My question is: can I use tapped holes in the baseplate, i.e. can tapped holes be re-used for an application where fatigue failure is a risk? (the baseplate itself is designed such that it is below the endurance limit). Because of space issues I can't get a nut on the underside of the baseplate.
Thanks in advance, KDB
