tc and rainfall duration specified - pond size calculation
phil_87
CA
I'm a bit of a newbie on calculating detention ponds etc.
Our regulatory agency requires the following:
- Use of a one in 5-year design storm for the allowable pre-development run-off rate
- Use of a one in 25-year design storm for the post-development run-off rate
- Size of outlet control control that is equal or less than predevelopment velocities
- Use a min. 3hr rainfall duration event and a minimum 1hr time of concentration
The agency prefers use of the rational method. The questions is if we have a relatively small area to be developed into residential lots of 1 acre.
Pre-development tc = 40min / C = 0.15 and post development tc = 25min / C = 0.35.
How can I calculate the pond storage using a tc of 1hr and a 3hr rainfall event by using the rational method, which as far as I have read up assumes that the storm duration equals the time of concentration?
Any suggestions or comments would be appreciated.
With modified rational method the rainfall duration is independent of the Tc. This allows you to develop a trapezoidal runoff hydrograph with a Tc of 1 hour and a rainfall duration of 3 hours. Frankly, I don't recommend the use of Rational method for pond sizing, but if you must that's how the hydrograph is developed.
For details and a sample hydrograph please see
Peter Smart
HydroCAD Software
Thank you.
What method do you recommend for Pond Sizing?
Any accepted hydrograph method, SCS/NRCS, Clark, & etc... I would say it depends on your regulating authority.
